Wrangler JL 2018++
- Marco28
Re: Wrangler JL 2018
Et ben !!!!! Il me plait bien ce JL mais à ce prix faut pas déconner
[ °O IIIIIII O° ]
JK 2.8L CRD 200CV
JK 2.8L CRD 200CV
- Bad Arrow
Ah, voilà, c'est ce tableau que j'avais vu! Merci roadwolf
WJ 2.7 crd Overland noir '04
- OlivierLB
Quelques info sur les axes de nos futures Wrangler
L Rubicon - Dana M210 Front / Dana M220 Rear
The flagship JL Wrangler is the Rubicon and to help make it more capable than ever before, it will come with an all new Dana M210 axle up front and a Dana M220 axle in the rear. Unlike any of the other JL models, these axles will measure an impressive 68" wide making them 1.5" wider than a Sport or Sahara and a whole 2.5" wider than what came on the JK Wrangler. I should note that full width axles are typically 68.5".
JL Sahara (Standard) - Dana 186MM Front / Dana M200 Rear
For those of you who want the luxurious options that a JL Wrangler Rubicon offers but don't really need it's impressive rock crawling capabilities, the JL Sahara is a perfect option for you and it comes with a Dana 186MM front axle and a Dana M200 Rear Axle. Unlike the JL Rubicon, these axles measure 66.5" wide which still makes them 1" wider than what came on the JK Wrangler.
JL Sport - Dana M186 Front / Dana M200 Rear
JL Wrangler Sports will now come with a Dana M186 front and Dana M200 rear axle. Just like the JL Sahara, these axles will also measure 66.5" wide.
JL Sahara & Sport Option - Dana M220 Rear
Available as an option, the JL Wrangler Sahara and Sport will also be available with a Dana M220 rear axle which comes as a part of the limited slip differential.
Selec-Trac AWD
While it's not an axle, it should be noted that JL Wranglers that are ordered with the optional Selec-Trac All Wheel Drive system will have front axle shafts that come with CV joints. This is done to help eliminate what some refer to as, "crow hopping" and provide smoother turning.
Selec-Trac AWD
- casa_47
Salut a tous , bon la taxe écolo on sait contourner , mais si on a pas de gros moteur V6 ben c'est pas le pieds ... pour la boite c'est pas un convertisseur ?? , c'est un double embrayage ?? c'est sûr de sûr ??
Configurateur US en ligne : https://www.jeep.com/build#/models/zipc ... SC,23B,APA
Wrangler 4xe Rubicon MY21
- Bertom
pcblate a écrit :Bonjour,
Très intéressant , merci pour ce lien
moi j'ai commencé a voir avec Madame.......
- OlivierLB
Interressant de constater que si on configure le rubi en standards européens (infotainement, V6, BM, ht couleur caisse et ailes couleur caisse, PC tole rubi, lampes led, plus qq bricoles type jantes, rails, systeme alpine pour un vehicule de cette gamme on arrive a 46470$...........
donc Finalement proche de l'europe! et en europe on aura une daube....
et malus annuel de 160 euros (avant augmentation...)Marco28 a écrit :Avec un bon malus de 10500€
et malus pour la carte grise
et malus quand tu revendras ton JK avant 10 ans
Et beaucoup de taxes quand tu rempliras ton réservoir après le 1 er janvier
merci Macron (je le comprend son premier ministre à les fesses douillettes et refusent la Business Militaire d'un 340)
- Marco28
Que ce soit Pierre Paul ou Jacques je pense pas que ça changerai grand chose
On se fait bien enfler
[ °O IIIIIII O° ]
JK 2.8L CRD 200CV
JK 2.8L CRD 200CV
- wrangler 17io
Je suis pas tout à fait d'accord...Je n'ai pas bcp de recul sur la politique nationale mais j'ai qd même le sentiment que les écolos tendent plus à gauche qu'à droite. Et MACRON reconnaissait son passif HollandisteMarco28 a écrit :Que ce soit Pierre Paul ou Jacques je pense pas que ça changerai grand chose
Tellement dingue qu'il ait été élu, mais y avait plus personne de crédible à droite, souvenez vous
TJ 2.4l de 2004, vendue itou
- jerem_
Je connais le malus à l'achat d'une neuve.
Le nouveau malus 2018, à l'achat d'une occasion.
Mais ce malus annuel m'avait échappé !' De quoi s'agit il exactement?
GROSS a écrit : ...et malus annuel de 160 euros (avant augmentation...)
JKU 2.8CRD 2014 POLAR
https://www.carte-grise.org/malus-annue ... uantes.phpjerem_ a écrit :BonjourJe connais le malus à l'achat d'une neuve.GROSS a écrit : ...et malus annuel de 160 euros (avant augmentation...)
- Kviper
pffff il est pas chers mai en faite il y a rien ............. si tu mets les option simpa tu arrive a 45-50000$
donc dans les 70'000 euros pour l europe quoi
1999 Jeep Wrangler TJ 4l
2015 renegade 2.0 black edition
et 2009 dodge viper srt-10 ACR (vendue pour d autre projet et surtout eviter les radars et la prison qui va avec
